Jandy pump noise, debris or bearing? Video attached
So I cleaned my pool the other day and I think some of the debris went through to the pump for the last two days my motor has been making a noise I have attached these two videos.
Steps taken:
Try to clean the impeller with a wet dry vac
Do noted that the noises coming from the motor side and not from the impeller side
https://www.youtube.com/watch?time_c...&v=M_j01X9Ifyw
https://www.youtube.com/watch?v=1Ksdfd2_a9k
pool/motor put in when home was constructed 2014.
Thank you for your help
