Thread: Green pool with resistant algae!
    Aug 2018
    Ohio
    Default Green pool with resistant algae!
    I have a green pool that seems resistant to everything I've tried!!
    Default Re: Green pool!
    That's common this time of year. There are multiple possible causes.
    One of the most common is elevated stabilizer levels, from the use of trichlor or dichlor (ie, the chlorine in most X-n-1 products) without compensatory adjustment of chlorine levels. If you don't know what your stabilizer level is, and aren't sure what 'flavor' of chlorine you've been using, this is particular likely.
    Another common factor is the use of all sorts of 'miracle pool additives', which combine to turn pools into disgusting cauldrons filled with a witch's brew of who-knows-what.
    The simplest fix -- for small pools that can be drained and refilled safely and cheaply, is to do just that, and then start over following the 'BBB Method' -- basically, just accurate testing + use of ONLY basic chemicals + regular appropriate dosing.
    Either way, you need to be able to test your pool appropriately: if you are in a hurry, get a HTH 6-Way Test Kit (~$23) (made by Taylor) from Amazon or Walmart . . . to start. Do NOT use the stabilizer / CYA test until AFTER you've added stabilizer. There are only 3x tests for CYA in that kit.
    But, you'll also need the K2006 if you don't already have one.
    Also, if you want to 'get it all' now, you'll also need refills for the CYA test: 16 oz bottle of R-0013 and Disposable plastic lab funnels. Try to order from Amazon rather than a 3rd party: Amazon handles shipping and warranties MUCH better.
    Once you have test results, post that PLUS info about your pool size, filter type, etc and I'll take a look.
    ________________________________________
    OR . . . you can just go to your nearest pool store with a water sample. They will undoubtedly have recommendations for MANY chemicals you need to correct "water balance", "high phosphates", "high TDS" and more. You can buy them; add them; and return the week following.
    Your choice.
    Upgraded membership and moved thread to the Algae section. You may need to log out and back in to see everything.
    PS.You can search use Google to search multiple pool sites, using Google's 'advanced search operators" to limit your search to specific sites. This page of mine will create the search links for you. Google knows my site -- and all the others -- much better than those sites internal search functions! And, if you need to post pictures -- of your pool, filter, pump, piping, what-not -- there are instructions on this page
    Please note: the Super Search page does NOT search directly; it only CREATES special Google links, that enable a FOCUSED Google search!
