Thread: Inground pool main drain, fill in ?
    Aug 2018
    ontario
    Default Inground pool main drain, fill in ?
    Hi All, I am getting my liner replaced and all 3 contractors who I got quotes from asked me if I want my main drain filled in with concrete. My pool is 25 years old and I never had a problem. Is it a northern climate thing because of possible freezing ?
    Default Re: Inground pool main drain, fill in ?
    If you have an existing pool, and have never had a problem with freezing in the past . . . you are probably good now.
    Removing the main drain makes it easier for them to install the liner AND harder for you to keep the pool clean, since dirt will accumulate in that deep in, with no drain present!
  1. Main Drain Clogged on Old Pool
    By sharpaaa in forum In-Ground Pool Construction and Repair
    Last Post: 07-01-2013, 03:05 AM
  2. Inground Pool Main Drain Plumbing
    By byron366 in forum In-Ground Pool Construction and Repair
    Last Post: 05-28-2011, 10:35 PM
  3. Plugging main pool drain.
    By grpargeter in forum Pool Equipment & Operations
    Last Post: 06-07-2010, 08:55 PM
  4. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  5. Can I operate pool with main drain closed?
    By Dafreak in forum Pool Equipment & Operations
    Last Post: 06-29-2006, 03:05 AM
