Results 1 to 9 of 9
Thread: Inaccurate Salt Reading and other problems with Aqua-Rite
    Virginia
    Default Re: Inaccurate Salt Reading and other problems with Aqua-Rite
    Which cell are you using (T3, T9, or T15)? If the main panel isn’t set correctly with the particular cell being used you can get wonky readings.
    Also, check where the cell and flow switch connect to the panel and make sure the connections are clean.
    Concerning the flow switch, make sure when installed the arrows on it match the water flow direction.
    When I started mine up last spring I got the solid no flow light. I made sure the connections were clean, and after running a little while it started working fine and has been fine since (I thought I might need a new switch).
    Aug 2018
    FL
    I am using a T3 cell. The arrows on the switch are lined up. I will check the connections, but the board is new. When I hold the flow switch and manually engage it the system goes to generating. It seems that the water isn't enough to make the connection engage in the pipe, but with the flow switch out the water comes gushing out. It doesn't see to have a block in the line and the pressure is the same as it's always been.
    Virginia
    I take it before the pool was resurfaced it worked fine? Any changes to the plumbing that might have altered the water flow at the flow sensor (turbulence)?
    Aug 2018
    FL
    Yes, before the resurface everything was fine. We didn’t change anything. I thought maybe debris was stuck in the pipe, but the pressure is the same and water gushes out of the pipe when the flow switch is removed.
    Virginia
    I’m stumped.
    You might have better luck doing the searches Ben suggested. I know some on troublefreepool.com are more knowledgeable about SWCGs.
    Aug 2018
    socal
    Quote Originally Posted by te619 View Post
    Average Salinity = 300
    Temperature = 86°F
    Voltage = 32.4
    Amps = 0.00
    Output % = 88P
    Instant Salinity = - 0
    Product ID = AL -0
    Software ver = r 1.59
    Cell type = t-3
    Thank you for posting the diagnostic and hope I’m not tool late in the game. I labeled the numbers accordingly to help others who are in the need to know. The above numbers indicate that your SWCG is not producing chlorine.
    Just a fyi, you can temporarily bypass the flow switch using an old 2 or 4 wire RJ11 modular telephone cord to test a "No Flow" error condition. Cut the tel cord, splice and twist together the 2 wires in the middle (normally green & red). Disconnect the flow switch from the mainboard and then connect the old tel cord in place. Run the pump, power on the swcg and wait for a minute. If the "No Flow" indicator stays on, then the mainboard is good. You can focus on the flow switch, ensure correct flow direction and inspect the wires for damaged.
    Since you temporarily managed to get rid of the No Flow error, the main board is good. The Aquarite flow switch requires sufficient flow of water to push the mechanical flapper to close the switch. Water gushing out does not mean there is sufficient flow of water to trigger the switch. There might be some restrictions in your plumbing or in case of a VS pump, you may have to bump the speed to satisfy the flow switch.
    JimK response is spot on. Makes sure the cell type match with what was shown on the display. Here’s the link to the Hayward Aquarite Troubleshooting Guidelines for your reference. http://haywarddocs.info/wp-content/u...ting-Guide.pdf
    Are you running the SWCG on a timer? It is possible for the swcg to display odd salinity readings if the cell is continuously powered on without the pump running.
