Re: Does Taylor R-0014 contain a chlorine neutralizer?
The chlorine neutalizer is sodium thiosulfate (plain photographer's hypo for anyone that ever had a darkroom). If I understand correctly the Taylor reagent already contains enought to work properly up to about 15 ppm chlorine. From my own experience the phenol red in the Aquachem kit works up to about 10 ppm. The first reagent in the ALK test in the Taylor kits (and Ben's) is sodium thiosulfate and if you are getting fasle high pH readings from high chlorine levels you can try adding a drop or two before the phenol red. The results will be more accurate but still have some error since the sodium thiosulfate itself can change the pH of the test sample.
It is entirely possible that it is not listed in the MSDS since they are only required to list the main indgredient and any "dangerous" chemical in a product There is really very little added to the phenol red. On some MSDS no ingredients are listed at all and it just says "Propriatary Mixture"
Sodium Thiosulfate itself is pretty safe...here in an excerpt from a MSDS for it in crystalline form
Potential Health Effects
Inhalation:
May cause irritation to the respiratory tract. Symptoms may include coughing and shortness of breath.
Ingestion:
Low level of toxicity by ingestion. Diarrhea may occur by ingestion of large quantities.
Skin Contact:
Irritation may occur from prolonged skin contact.
Eye Contact:
Contact may cause mechanical irritation.
Chronic Exposure:
Chronic exposure may cause skin effects.
Aggravation of Pre-existing Conditions:
No information found.
Now this is the same section from a MSDS for Sodium Chloride (commen salt). You can see that salt causes much more severe problems when ingested, gotten in the eyes, or absorbed through the skin than sodium thiosulfate! (but don't eat or drink the chlorine neutralizer!
Inhalation:
May cause mild irritation to the respiratory tract.
Ingestion:
Very large doses can cause vomiting, diarrhea, and prostration. Dehydration and congestion occur in most internal organs. Hypertonic salt solutions can produce violent inflammatory reactions in the gastrointestinal tract.
Skin Contact:
May irritate damaged skin; absorption can occur with effects similar to those via ingestion.
Eye Contact:
Causes irritation, redness, and pain. (For salt concentrations greater than the normal saline present.)
Chronic Exposure:
