Thread: Well Water With Iron and other good stuff.
    Default Well Water With Iron and other good stuff.
    I filled my pool with all well water. Should I use some type of iron out?
    The water is pretty cloudy and green, which I am working on also.
    Another thing. Is the so called "Shock" from the pool store the same as bleach?
    Mike
    Default Re: Well Water With Iron and other good stuff.
    Quote Originally Posted by mikeydiker
    I would use a metal sequesterant before shocking so the water doesn't color from the iron (yellowish brown) and so you don't get any staining
    'Shock' is a verb, not a noun. It is something you do to your pool by raising the chlorine levels to 10 ppm or higher, depending on your CYA (stabilizer) levels. See this thread:
    http://www.poolforum.com/pf2/showthread.php?t=365
    You can shock with any form of unstabilized chlorine, sodium hypochoroite (liquid chlorine and bleach), Calcium hypochlorite ( the powdered stuff ususally labeled shock), or lithium hypochlorite (VERY expen$ive....very few use it because of the price)
    Mike
    Hope this helps.
  1. Well Water very High Iron
    By meadsrm in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 03:58 PM
  2. New Pool Owner With High Iron Manually Removing Iron
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-18-2010, 03:56 PM
  3. I'm usually good at this stuff......
    By Madty in forum Dealing with Algae & Slime
    Last Post: 07-03-2006, 10:59 AM
  4. Good Online Store For Canadians To Purchase Pool Stuff
    By tenax in forum General Interest
    Last Post: 07-03-2006, 06:54 AM
