Thread: Plaza pool plumbing
    Sep 2018
    Missouri
    Default Plaza pool plumbing
    Live south of St. Louis. Pool put in 9 years ago. It never required the lines being blown or antifreeze because of the way Jerry did the plumbing. He passed away. anyone out there know how that might have been done? I know there is a line that has to be sealed at opening. Sealed now. Water is drained below skimmers. Pool equipment at lower height than pool. Thank you
    Default Re: Plaza pool plumbing
    Your only chance of finding out the specifics of how your pool was built is to ask locally, not here.
    If you know anything about the builder, you might try calling SCP (pool wholesaler) in St Louis:
    Address: 11540 Adie Rd, St. Louis, MO 63146
    Phone: (314) 993-0077
    and see if they can help you find someone who worked on your pool.
  1. Question in regards to pool plumbing
    By DennisP in forum Pool Equipment & Operations
    Last Post: 09-09-2014, 11:30 PM
  2. Above ground pool plumbing?!
    By gmarquis38 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-28-2014, 11:14 PM
  3. intex pool plumbing
    By darenjones in forum Above-Ground Pool Construction & Repair
    Last Post: 07-13-2006, 04:38 PM
  4. pool plumbing and design
    By us7sail in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2006, 02:57 PM
