Thread: Do 3" tablets go bad?
    Default Do 3" tablets go bad?
    Cant get my cholrine up.
    Been using aqua chem 3" tablets in a floating dispenser. Previous years I just set it on full open for about the first week I open pool and rest of year 3/4 of the way close. This year been open for a month and cant get the cholrine level up. Tried different test kit also. And I even got another dispenser so 2 are in use with the tablets. Tablets left over from last year when I got from sams club. Could they go bad.
    Only other change this year I added a solar panel.
    Thanks for any suggestions
    Default Re: Do 3" tablets go bad?
    Please post a full set of test results for Free Chlorine, Total Chlorine, pH, Total Alkalinity, Calcium Hardness and CYA (stabilizer).
    Also please post the surface of your pool (plaster, vinyl, fiberglass) and the volume in gallons (or the dimensions, average depth and shape)
    Then we can get a handle on what is happening in your pool. If you have the test results from when you closed the pool, particularly the CYA level post that also....it might help!
  1. 3" HTH tablets clogging my filter?
    By shoveler in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-06-2012, 08:05 AM
  2. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  3. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  4. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
