Results 1 to 8 of 8
Thread: Pool Startup New Water?
    Apr 2012
    san diego
    Default Re: Pool Startup New Water?
    The filter grids that I bought some time ago are FS-2005, 60 sq foot. How do I know how much DE to add? The amount I add always seem to clog up the grids and reduce the flow. One top of the grids is broken so I will buy a new set on Amazon and replace before adding DE.
    36K gal IG free form plaster pool
    Apr 2012
    san diego
    Could I use pucks to bring the stabilizer level up?
    Yes.
    Dichlor is 55% chlorine, 50% stabilizer; trichlor is 90% chlorine, 55% stabilizer.
    (Yes, I know those %'s don't add up right. Long history behind that, which I'm not going to explain here. Trust me, it will work out the way the %'s imply)
    Apr 2012
    san diego
    Thanks PoolDoc
    My tabs say Triclor-S-Triazinetrione. I'll start chlorinating the pool with them and watch the CYA very closely. I'll check the PH. I have acid. I believe Borax was the agent recommended by you to raise the PH if need be.
    I'll review my pool chemistry.
    Quote Originally Posted by atkinson40 View Post
    . . . one of the names for trichlor.
