Thread: metal sequesterant. What to use?
Threaded View
  1. #5
    Default Re: metal sequesterant. What to use?
    Just about every sequesterant on the market is based on the same group of chemicals (dreivatives of phosphonic acid) I know of one that is based on the chelating agent EDTA, MetalFree by NaturalChemisty. I have used that one along with several others and they all seem to work. Can't really tell you which one is best but I have had good luck with the MetalFree, Proteam's Metal Magic, and the Jack's Magic line (the Pink Stuff for iron). Just make sure to follow the directions for dosing, pH,and water balance instruction before you use one for it to work properly. Adjusting your pH to the proper levels recommend on the label first is a most important step!
  1. Where is the metal's forum?
    By Bossone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-06-2012, 06:00 PM
  2. have a little metal what to do
    By gone01 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-15-2011, 08:15 PM
  3. Metal Removal
    By wilkej in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-01-2011, 12:19 PM
  4. Do I have metal problems?
    By sw_stupid in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-18-2006, 10:37 PM
  5. algae or metal??
    By woman.n.a.shoe in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2006, 11:46 PM
