Thread: test results and SWG questions
    Default Re: test results and SWG questions
    all pool stores are variable in their water testing. It depends on the person doing the testing. If they use a meter to test for salt ask them how often they calibrate it. It it is farly often (at least every few weeks) then it should be ok.
    Cedar Hill, TX (Dallas)
    I think you need to drop your AutoPiliot to level 1.
    Read the startup section of the manual (page 11)... I normally run 80-90%, and should bump to level 2!!!
    Thanks!
    Robert
    Leslie's also sells a salt test kit on-line made by Taylor. It uses the std test tube and includes R-0630 (chromate indicator) and R-0718 (Silver Nitrate Reagent).
    I just tried it for the first time just now as I'm using 80lb bags of softener salt to weigh down my drop-in steps. The water tested at 1000ppm and the kit worked EXACTLY as described.
    Not that I care about salt as I don't have an SWG, but I wanted to play with the new toy!
