waterbear
What you have is dichlor and trichlor, both are stabilized chlorine and using them will cause your CYA(stabilzier) levels to rise. It would be fine to use them now instead of buying stablizer and then when you CYA is 30-50 ppm switch to bleach. Be aware that the trichlor tabs are acidic and can lower your pH...use borax to raise it if this happens. the dichlor doesn't have much impact on pH and would be good to use as shock (if it is in granular form) right now since it dissovles quickly and will help get your CYA levels up. Just keep close tabs on your CYA.
