Results 1 to 10 of 13
Thread: Well Water: Why you DON'T shock BEFORE using Sequestering Agent
    mbar's Avatar
    Ashland, PA
    Default Re: Well Water: Why you DON'T shock BEFORE using Sequestering Agent
    What are all of the numbers for your pool? cl, cc, ph, alk, cal. Sometimes it is when you have high ph, or high alk with high calcium and high chlorine that you get stains. Ascorbic acid (vitamin C) will also take the stain off.
    Northeast PA
    Have a wallyworld test kit so I cannot do some test.
    Hardness test seems to not be working correctly.
    5.0 CL (seems to be around 6-7 kit only checks to 5)
    7.8 PH
    130 TA
    45 CYA
    I think my problem was shocking the night before I added water in the early am. Need to try to add fill water when chlorine is on the low side.
    And of course keep using metal free.
    cj
    mbar's Avatar
    Ashland, PA
    A ph of 7.8 with an alkalinity of 130 plus high chlorine is what will make the metals fall out of solution. A water softener will make the water more alkaline, but should also help to take metals out of the water, but it is not getting all of it out. You will have to keep sequestering agent in the water to keep the metals that are getting in tied up. I add water from a well also. I like to keep my ph no higher than 7.6, and my alk around 100. When I add water I drop my ph down to 7.2, and put a trichlor puck in the skimmer. You can do this with a sand or DE filter - NOT a cartridge filter. This way if there isn't enough sequesterant in the water, the stain should fall on the filter first. Sometimes lowering the ph and adding sequesterant will take the stains off the pool, if they are not to embedded. Since the stains are on the steps only, you can also try putting some ph down in a sock and rubbing it on the stains. Hope this helps, feel free to ask any questions you may have.
    Northeast PA
    Thank you for the help!
    Will make a note of this!
    cj
    Sand filter, 20-40 vinyl liner
    vwb1975 is offline ** No working email address ** vwb1975 0
    that is exactly what my pool looks like. What was the name of the sequestering agent that you used? I have a 14000 gallon AG pool. I am postitive that you took a pic of my pool.
    mbar's Avatar
    Ashland, PA
    Sequasol, or Jack's Magic, Metal free are all good, they are the one's I have tried so far.
    Northeast PA
    Is metal magnet just as good?
