Re: pH of 3.5 - Never before.
I'll have to check my TA.
I'm testing using a digital meter. I Double checked the calibration twice and it's fine.
I also tested my spa.... fine.... and house water.... fine.... normal readings.
I will say, that I checked the pH this afternoon and it was up to 6.5. So I aded 8 more pounds of soda ash. After 4 hours it now is ok with a reading of 7.6.
I can only assume it was those pucks.... I'll keep the auto feeder turned down more.
Thanks, Tim
