Results 1 to 8 of 8
Thread: Spa "return(s)" versus spa "jets"
Threaded View
  1. #4
    Default Re: Spa "return(s)" versus spa "jets"
    Sometimes in a shared system the spa jets use a booster pump to supercharge them. Sometimes a blower is used for this also. In either case the main pump needs to be running and the valves need to be in the spa position. Usually when there is a second pump for the spa only it also has separate filtration, heat, and sanitation and works independantly of the pool system.
