Thread: Why can't I find the proper replacement basket for my Jacuzzi J-VSP 250 pump?
    Apr 2014
    Default Why can't I find the proper replacement basket for my Jacuzzi J-VSP 250 pump?
    Help. I am trying to find the correct basket for my Jacuzzi pool pump. Everything I have found seems to have different dimensions. Is the Jacuzzi brand proprietary to Leslie's? I have a great dislike for the local store. I have searched a number of online stores and am up against a wall. The OEM part number gets no hits. Any suggestions? Thanks
    Apr 2014
    Default Re: Why can't I find the proper replacement basket for my Jacuzzi J-VSP 250 pump?
    Help again. How do I find the correct basket? I called Jacuzzi and they had me call Leslies. The fellow took great pains to help me but was only able to find the one Leslies says is correct. They must have changed the design as the dementions are not what I have. Any help would be appreciated. Thanks
  1. Pump not pulling in water to strainer basket (clogged pipe?). Pump is okay.
    By CountryBumkin in forum Pool Equipment & Operations
    Last Post: 01-15-2017, 02:58 AM
  2. Jacuzzi pump leaking at motor
    By poolbee in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 10:26 AM
  3. Spring replacement for Jacuzzi Splash-Pak valve
    By Ken_J in forum Pool Equipment & Operations
    Last Post: 06-25-2007, 05:01 PM
  4. pump will only prime when basket is out
    By ScottsdaleSwim in forum Pool Equipment & Operations
    Last Post: 10-15-2006, 11:01 PM
  5. How often should you clean your pump basket?
    By Beachnut_PA in forum Pool Equipment & Operations
    Last Post: 06-26-2006, 12:20 PM
