Thread: Polaris 380 does not run correctly
    Aug 2010
    Default Polaris 380 does not run correctly
    With the booster pump on and (backup valve & Polaris disconnected from hose), I get low water pressure from Polaris hose. Equal to if you just turned on your outdoor water hose to low.
    Should I higher water pressure than this?
    May 2014
    Sussex, WI
    Default Re: Polaris 380 does not run correctly
    I haven't used my Polaris for a few years because I switched to a non-pump driven cleaner. Having said that, When I was using it, I always would watch the action of the tail. If it wasn't sweeping back and forth frequently, I knew something was up. Once in a while, that something was some debris that would get through the filters into the pump. The good news is that's the least likely. Most of the time though, it was a hose connection that came loose. Check those first. That includes the connections inside of it.
    25k gal pool, 18 x 36, 3' to 8' depth. Vinyl lined. Single speed pump
