Results 1 to 10 of 12
Thread: What causes Calcium to rise?
    Default Re: What causes Calcium to rise?
    You can always check over in the Chlorine Feeder and Salt Water Generator section for scaling issue with SWGs and high CA. I am not familiar with that, but there are others over there that could address that possible issue.
    I remember that this site was established to avoid adding other things to your pool. The more chemicals you add, the more problems you could incur. Don't forget that rain water will enter your pool too (hopefully) and that will not have any calcium in it.
    Take Care.
    Harry
    but, depending on water conditions, some extra chemicals like sequesterants, could be necessary!
    SoCalBoo is offline Registered+ Thread Analyst SoCalBoo 0
    San Diego
    Thanks guys. Just worried about the SWG and the heater (pentair MiniMax NT). Draining 1/2 of the pool and rebalancing frankly sounds cheaper and easier than replacing the heater and cheaper than replacing the salt cell. Admittedly, I have NO idea about how long it would take the elevated level of calcium to render either unusable. Haven't made up my mind yet, so just reviewing my 'options'.
    As for rain water, I live in san diego, so not expecting much help there.
    mas985's Avatar
    Pleasanton, CA
    SoCalBoo,
    I am in a similar situation and just replaced some of my water when my CH got above 400. I started to see some scaling on my SWCG when my PH got above 7.6 so I did a partial refill ~25% and keeping my PH between 7.2-7.4 has so far eliminated the scaling.
    Mark
