Closed Thread
Results 11 to 18 of 18
Thread: Hit the Lights
    Philly Burbs
    Default Re: Hit the Lights
    I wonder how far up the corporate ladder pool dude will climb.
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    Our "fiberstars" light is broken.. this story makes me really scared. The guy is coming to try to fix it tomorrow or Wednesday.
    abessellieu is offline ** No working email address ** abessellieu 0
    Jul 2006
    Bryn Mawr, PA
    Smile Re: Hit the Lights
    Dear Thilbert,
    Are you related to Ogden Nash? No? Oh well, never mind, you're funny in your own right. Thanks for the laughs. I needed something to tickle my funny bone while in the midst of my own pool renovation trials and tribulations.
    Jan 2006
    Atlanta
    I've got a similar problem.
    Last year there was water in my light housing. Pool Guy looked at and said I needed a replacement.
    Ok, since cost was $150. He proceeds to remove bezel, housing, bulb, etc. Then cuts off wire.
    Comes back next week and tries to fish wire from new light into light opening. Will not go, probably because there is some type of junction box.
    Now I've had my electrician run a completely new wire and next season when the liner is replaced we may able to fish the new light to a new junction box. Here's hoping.
    Socal_biker Guest
    I last changed the pool light bulb 3 yrs ago. Now that I have the pool drained and cleaned, I decided to replace the pool light with a new color wheel unit (SAm).
    It was pretty straight forward swap.
    • Made sure the pool light switch was set to the off position and turned off the circuit breaker to the pool light.
    • Solid conduit going from the niche to the GFI outlet near the diving board.
    • I just undid the two wires on the GFI outlet and untwisted the wire nut for the light's ground wire.
    • Pulled the old pool light wire through the conduit from the niche end.
    • Fiched up the new pool light wire through the conduit and wired the new light to the GFI outlet.
    My layout was a near exact match to this diagram:
    Picture is from the Owners manual for the Pentair Spectrum Amerlite SAm light.
    My light ring's finish was pretty worn out, chrome finish worn through. The heavy & thick metal ring was showing the copper base metal (or rust?).
    I tried getting a replacement light ring at the pool store, but my light ring was an old discontinued line (Aladdin ~30 yrs old). A replacement light ring adapter was going to be $$ and would have to be special ordered.
    I decided to have it refinished, it would be a less expensive route. Re-chroming would take some time, so I had it powder coated with a chrome like finish and then clear coated to resist the pool chemicals. Cost me $40 and a two day turn around.
  6. #16
    y0manda is offline Registered+ Thread Analyst y0manda 0
    I have a question for the San lights. I have two in the pool and they were in synch at first. then after a couple of weeks of them being hooked up, One light was in the green and the other was in the blue. Then oddley enough they kinda adjusted themselves again, but not perfectly. Last night I pulled the plate off the goldline control box and checked out the wireing for the lights and they are not hooked up individually at the box, they must be piggy backed somewhere else. Because what I wanted to do was d/c one of the lights at a point in color. then have the other light shut off where the other light stoped. then reconnect everything again but couldnt tell how. I was wondering if there was another approach to synching the two lights. Thanks.
  7. #17
    Socal_biker Guest
    SAm operation & synchronization.
    Just a series of turning the lights on/off to synchronize multiple SAm lights onto the same color.
  8. #18
    heh, thanks socal
Closed Thread
  1. adding fiber optic lights to existing pool/spa lights
    By jjjjj in forum Pool Equipment & Operations
    Last Post: 07-07-2012, 12:30 AM
  2. LIGHTS, uh camera, what is next?
    By GatorWayne in forum Pool Equipment & Operations
    Last Post: 04-11-2012, 10:02 PM
  3. Pool lights
    By JJNMRSDAD in forum Pool Equipment & Operations
    Last Post: 07-01-2011, 12:27 AM
  4. lights
    By Cotton in forum In-Ground Pool Construction and Repair
    Last Post: 06-08-2011, 07:21 AM
  5. Pool Lights
    By Jinx32 in forum Pool Equipment & Operations
    Last Post: 09-09-2006, 10:46 PM
