Results 1 to 10 of 11
Thread: DE escaping from the filter into the pool...
    Default Re: DE escaping from the filter into the pool...
    I hypothesized that the DE around a hole in the fabric would show signs of erosion. So, without rinsing off the DE from the grids, I disassembled and examined each panel. As I found these eroded patches, I marked them with a Sharpie.
    When I finished searching, I risnsed off the grids, leaving just the demarcations (around holes of varying sizes and shapes.) The air bleeder was in the worst condition, a 1/4" opening at the tip.
    I checked and relubricated the O-rings. Then, I sewed up the air bleeder and patched the grids with low-temperature hot melt glue. The MSDS claims that the glue has very low water solubility/ extractives and is stable at pool water temperatures.
    When I reassembled the grids, I noticed some of them no longer seated perfectly against the manifold because their frames were cracked. But I figured to get one more season from them before buying a new set.
    After vacuuming up the DEbris (sic) at the bottom, I ran the pool pump/filter for several hours with no detectable DE in the pool/spa. I had almost forgotten what "polished" looked like.
    Waste, Thanks for your advice and support.
    Scottsdale Arizona
    wen- glad to hear you solved your problem! I received the new air bleed screen and it's just that- screen. The old one was a fabric of some sort. I still haven't installed the new one. I need to drain a little anyway as my cya is off the chart.
    Getting those grids into the manifold is tricky and frustrating at times. We replaced the grids because we found a tear in one and a crack in the end that goes right into the manifold. I purchased mine online for 108.00 but I have a 36 sq ft filter area.
    Much cheaper than buying them locally.
    I'm hoping the new strainer will work and completely clear it. The little bit of DE settles into the liner creases and drives me batty.
    Quote Originally Posted by ScottsdaleSwim
    [...deleted] Much cheaper than buying them locally.
    About 50% cheaper even with S&H. Good luck with your DE filter. With my DE problem addressed, I am observing my Polaris, which lingers in the northern corner of my pool .
