Results 1 to 10 of 44
Thread: iron and copper
    Unhappy Re: iron and copper
    Sad to say, my situation is not any better. After the pool magnet failed to work the third time I decided to go the BBB route and at least get my pool
    balanced and then try to deal with the metals, after 4 days of keeping the
    chlorine at 15-20, and the Ph at 7.6-7.8 I now have yellow- brown cloudy water and visibility of about 2 feet. I am loosing patience as I have a huge
    picnic/campout planned in 2 weeks and do not see sparkling water anytime soon.
    mbar's Avatar
    Ashland, PA
    Default Re: iron and copper
    The reason you are testing no metals in the water is because the sequesterant -pool magnet, is holding the metals in suspension. THere is no way I am told to get the metals out of the water once they are in there, except by a very complicated way that Pool Doc had talked about. I will explain how staining occurs. When there are metals in the water, and you have your ph above 7.5 and get your chlorine levels up high as when you shock the pool, it can casue the metal to precipitate out of the water. This can cause the pool surface to stain. It also causes the pool water to appear light green, or brown. What I do when I open the pool is to add sequesterant first before any chemicals. Leave the ph about 7 to 7.2, and slowly raise the chlorine. If you have a sand or DE filter you can put a trichlor puck in the skimmer basket (this will help by the water going over the puck, if the metals precipitate out they will stain the filter instead of the surface of the pool) keeping the filter running 24/7. Do not do this if you have a cartridge filter. I also had success when my pool was cloudy after a stain treatment, putting in a flocking agent. I let the water sit for 24 hours without the filter running, then vacuumed to waste. I shut the filter off everynight and vacuumed to waste in the morning. I did this till there wasn't any stuff on the bottom, and the water was clear. Whenever I added fill water, I added it through the skimmer with a puck in it. When ever I have to shock, I make sure my ph is down around 7.2. I try to keep my chlorine level constant by testing each evening and adding enough chlorine to keep it in the perameters of the "best guess chart", this way I very rarely have to shock the water. Hope this helps, if you have any questions feel free to ask.
    Northeast PA
    szampino is offline Registered+ Thread Analyst szampino 0
    Marie,
    I've been reading all the threads you, Dave S and others have posted on Metals. Some I understand and some I don't. Everyone on this forum is a Clorox Bleach vs Chlorine supporter.
    Q1. If I switch, will this help? **I prefer not, but will if I need too.
    Just an FYI - I actually sampled my water without any chemicals present and was told it didn't have any metals but chose to Pool Magnet anyway because of the trouble I had last year, thinking I'd beat it this year.
    Q2. What do you suggest I do?
    - Chem out
    - Re-Pool Magnet
    - Then never shock again and keep my Chlorine and PH levels Low?
    Q3. Why do I have to shock if there doesn't apear to be any living problems?
    Thanks for being supportive!
    mbar's Avatar
    Ashland, PA
    Sorry it took me so long to get back to you - I have been battling floods - in the basement, and in my pool!. Anyway, your water won't show metals if there is enough sequestering agent in the water because the sequestering agent bonds onto the metals and keeps them from showing up - it also keeps them from staining the pool and water. It does not matter what kind of chlorine you use, as long as you follow the "best gusess chart", which can be found as a sticky at the top of the chorine forum. So it doesn't matter if you don't use bleach.
    You don't have to shock if you A) have no combined chlorine, and B) if your pool is holding it's chorine overnight, and the water is not cloudy.
    I would suggest you add more sequestering agent (pool magnet), any chemical that says it will get rid of metals. It doesn't hurt to have more sequestering agent in the water than you need, but not enough and you will get stains. Then I would keep my ph low whenever you want to shock your water, or run your chlorine on the high side. If you have a sand or DE filter you can keep a trichlor puck in the skimmer - it helps to let any metals that will precipitate out stain the filter instead of the pool. DO NOT put a puck in the skimmer if you have a cartridge filter.
    Hope this helps, please feel free to ask any questions you may have. It took me a long time to understand stains - and I a still learning!
    Northeast PA
    Sorry to hear about the flooding! I hope you win!
    Just wanted to give an update.
    Bonni - if you haven't had any luck try what I just did.
    Mbar- Thanks for all you posts it really helped a lot.
    This is what I did so far. I went to my HealthFood store and bought 2 (8oz) bottles of Vitamin C (Crystals) (expensive but I was desperate). The Vitamin C will bring down the Chlorine levels fast, and Pool Magnet works at 1pm Chlorine levels. Then I followed some of the instructions that Mbar has posted. Turn the filter off, put the C in and I let it sit for about 1/2 hour. Then I turned the filter back on, added 1 qt of Pool Magnet Plus and let it run overnight. I woke up this morning and it looks like the water is almost back to its Crystal Blue state. Don't know how much impact the rain had but whether it was a little help from God or the Metal Forum Gods it appears I'm on the right track.
    The next plan is as follows (would welcome some input).
    I expect my pool to get cloudy (due to the pool magnet) I'm going to get a flocking agent and try it. Then I'll vaccum the pool.
    I am going to slowly raise my PH to (ok) levels. Then I'm going to slowly (did I say slowly) raise my chlorine levels to the lowest possible (Ok) level. I will be continually adding the maintenance dose of Pool Magnet per week.
    Q. I was told by my pool store that they make a non-chlorine shock. Do you think it will react with the metal? Do you have any experience with this?
    Do you have any other suggestions for me?
    mbar's Avatar
    Ashland, PA
    If your water didn't get cloudy yet, it probably won't. Keep your filter running 24/7 for a while. Don't use a flocking agent unless the water does not clear with filtering - sometimes the less you do to the pool the better. I only suggest flock when the water doesn't seem to clear once you hold chlorine at the proper level for about 2 days, and there is no combined chlorine.
    Here is a link to get ascorbic acid (vitamin C) which I am sure is cheaper then buying the crystals at a health food store, you might want to keep some on hand - sometimes when you are prepared you don't need it (ha ha), that's what happened to me this year!
    http://www.msm-msm.com/store/agora.c...scorbic%20Acid
    Northeast PA
    thanks a gazzilion!
    ***I'm sure I'll be back, but right now, I feel pretty successful that I understand the problem, and can adjust accordingly.
    Thanks again.
