Results 1 to 10 of 44
Thread: iron and copper
    mbar's Avatar
    Ashland, PA
    Default Re: iron and copper
    THis is how I understand it, chlorine comes in 2 parts, stabalized chlorine and "fighting chlorine" If there i isn't enough of the "fighting" chlorine in the water to fight anything that is introduced to the water, you can get an algae bloom. The cya binds onto chlorine and stabalizes it - which is good, because there will be a level of chlorine always maintained in the water. This will keep it sanitized, but if something new comes in there is no "fighting" chlorine to battle it. That's how so many people get into trouble with their water - they have enough chlorine in the water according to the kit, but the chlorine is binded with the cya, therefore not leaving any "fighting" chlorine in the water. Ben came up with this chart to keep you with enough of the fighting chlorine in your water depending on how much cya is in the water. Hope this makes it more clear for you, so you can understand the importance of keeping up with the chart. If you keep your levels consistant, you shouldn't have to shock. Just bring your chlorine up slowly and if you start to see the water change color add more sequesterant and take your ph down to 7.2.
    Northeast PA
    All of the sequesterants that I have seen want you to have your chlorine below 2 before you can use them, is this really necessary? I have a hard time getting my chorline up to 5-10 where it should be, once I hit 3-4 it starts to stain again and then I have to drop it to put in the sequesterant. I feel like I'm in a cylcle that can't be broken.
    mbar's Avatar
    Ashland, PA
    I always add the sequestering agent no matter what the chlorine is. I think the reason it is stated to have the chlorine low is to give the sequestering agent a chance to work before the metals fall out of suspension when you raise the chlorine. You need it to get the green out - with a low ph it should work. I wouldn't lower the chlorine.
    Northeast PA
    szampino is offline Registered+ Thread Analyst szampino 0
    Bonni,
    Why do you have to get the chlorine up to 5 - 10?
    Mbar- Is there a problem keeping it between 1-2?
    So far, my water has been almost perfect. I am not planning on raising my Chlorine above 1-2 unless I see a problem.
    All comments welcome.
    **last year I had a problem with the cloudy water (same entex 18x48) Nothing fixed it. But my remedy this year if it happens again is to treat it like staining, add Ascorbic acid, which will bring down the chlorine and then slowly raise the chlorine again until it gets between 1-2.
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    Do the metals always fall out of suspension when you raise the chlorine? It seems like this will be a never ending cycle
    mbar's Avatar
    Ashland, PA
    szampino, the reason I told bonni to raise the clorine is that she has a cya of 70. With a cya of 70 you need to have the chlorine between 5 & 10. The water may be cloudy from algae starting and never getting completely killed. It is more important to have a sanitized pool, you can swim with metal in the water, but I wouldn't swim with unsanitized water. If you have a cya level of 20 or less, then it is fine to keep your chlorine at 1 to 2 ppms. You just have to test often and not let it go down to 0, because then you are leaving yourself open to an unsanitized pool.
    Gerri, as long as you have enough sequestering agent in the water, you will be able to shock without stains forming. If you keep your chlorine at the right level, and never get a combined chloirne reading, it isn't necessary to shock. You will get the hang of how your water reacts - when you shock, always bring your ph down to 7, or 7.2 before you add the chlorine.
    Northeast PA
    Jul 2006
    Upstate, SC
    Do you use muriatic acid to bring down the ph?
    mbar's Avatar
    Ashland, PA
    yes, you can go on the bleach cal, click on more calcs and it will show you how much you need to bring it down in increments of .2
    Northeast PA
