Results 1 to 10 of 44
Thread: iron and copper
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    Default Re: iron and copper
    Good luck getting your water cleared. I think bringing your chlorine back in slowly may help. Keep us posted as to how it goes. I have cloudy water right now from Ascorbic Acid, but I'm in the middle of my stain removal so I'm not letting it bother me.
    szampino is offline Registered+ Thread Analyst szampino 0
    Thanks for the quick reply - I will keep the post updated with my progress
    mbar's Avatar
    Ashland, PA
    szampino, you don't need ascorbic acid unless you have staining. You just need to make sure you have the sequestering agent in the water - that is what holds the metals in suspension. You need to keep your chlorine no lower than 3ppms at all times with a cya of 30, if under a chlorine of 2ppms is the lowest. Since you had cloudy water, you want to keep your chlorine at shock levels till the cloudiness goes away! The ascorbic acid is what made the pool cloudy - you will now use up a lot of chlorine breaking down the ascorbic acid - so keep checking and don't let it fall under 3ppms for now, and you can even keep it up to 10 if you didn't have any staining before putting in the ascorbic acid. The only reason you have to take the chlorine up slowly after doing a stain treatment is in case there is any metals that have not been sequestered after the ascorbic acid lifted them, they will fall back out. Since you had no stain to lift, then the metals were already sequestered and you can raise your chlorine. Just keep your ph low when raising the chlorine - no higher than 7.3. Hope this explains a little more to you - feel free to ask any more questions you may have. If you are afraid metals have been introduced into the water,then it is a sequestering agent you want to add, not the ascorbic acid. The ascorbic acid is only to lift stains that have precipitated out of the water.
    Northeast PA
    Mbar -
    First of all Thanks.
    The cloudyness in the water appeared before I AA'd.
    I added PoolMagnet, then slowly brought the Chlorine up to 10(+) in hopes of removing the cloudyness. I left the chlorine level at 10+ for about 1-2 hours. I then added AA (thinking that the cloudyness was due to Metals) I knew the AA would bring down the Chlorine level pretty quickly. I then began to raise the Chlorine level to 1-2 where I plan on keeping it. I also wanted to make sure the Chlorine would hold, so I brought it up twice throughout the day and it maintained all night so I was pretty sure the AA wasn't attacking the Chlorine.
    Throughout the whole process the cloudyness didn't budge.
    This morning I took a sample down the PoolStore to get a reading and any suggestions they may have.
    The readings were as follows:
    TC 1.3
    FC .9 (A little lower then my test strips showed)
    pH 7
    TA - 107
    Hardness-120
    Copper & Iron- 0 (it looks like the PoolMagnet is working)
    **I saw some info on Calcium hardness and tried to raise it to the 200 level but obviously haven't gotten it that high yet. Then I read the 100 cloudy water causes and saw under the myths that WaterHardness does not make cloudy water.
    The pool Store recommeded raising the Chlorine to 3 and keeping it there. I've got it just about 3 now and am holding steady, not change in cloudyness.
    Last year I had the same problem, Cloudy, (I define cloudy as I can see the bottom of the pool but it isn't very sharp. I can't actually see the small designs on the vinyl.) I couldn't get it clear for the life of me.
    This year I thought I almost had it licked through the info from this site and especially your posts.
    Q1. Can the metals be causing the Cloudyness? if so, should I add more PoolMagnet? What about AA-(tried this but I didn't add a lot only about 1/2 lb)
    Q2. What about clarifiers? I'm afraid to add more stuff before I know what I'm dealing with.
    Q3. Doesn't too much Clarifyer or Too much pool magnet also cause cloudyness?
    I think I'm almost about to POP my POP!
    mbar's Avatar
    Ashland, PA
    I would not add anything else yet. I would however bring the chlorine up to 10 - 12. You are fighting something because you have combined chlorine. I think if you take the chlorine up to 10 or 12 and leave the filter on 24/7, the water will clear. I don't have any experience with cartridge filters, as I have a sand one, so I don't know how long it will take to filter out what the chlorine has broken down. Take up your chlorine, and your POP, and I think it will do the trick.
    Northeast PA
    OK -
    I had it up (10+) all night. (Filter 24/7)
    No change at all, no better no worse. One thing I find interesting is that I have a fountain on the pool return. The splashing of the fountain appears to create some bubbles on top of the water that linger for longer then I would expectected
    I've just changed the cartridge filter to rule out a dirty cartridge.
    TA-80 (a little low)
    PH - 7.0 - 7.2
