Closed Thread
Thread: used doughboy above ground
    Carterville,IL
    Default used doughboy above ground
    I am thinking of buying a nice used (2yr old) doughboy above ground pool for $2500 for everything but the landscaping. I understand I will HAVE TO buy a new liner......anything else I should check out? Pool krete or sand? I live in the country and moles ARE an issue???? I have heard both....sand will be ok and definately pool krete....HELP!
    Default Post has been moved by moderator
    I have moved this thread to the above ground pool equipment and construction forum. Any replies to the question should be posted there.
    Thank you.
    Watermom
Closed Thread
  1. Second summer with our Doughboy
    By laurenfitz in forum General Interest
    Last Post: 06-13-2013, 11:06 PM
  2. Above Ground Pool Research - Doughboy vs Leslies Pools
    By pamedalah in forum Above-Ground Pool Construction & Repair
    Last Post: 04-24-2012, 12:44 PM
  3. Need advice on plastic caps for doughboy above ground uprights...
    By ragriffin in forum Pool Equipment & Operations
    Last Post: 04-22-2012, 05:14 PM
  4. New liner for a 28' Doughboy
    By jrh1010 in forum Above-Ground Pool Construction & Repair
    Last Post: 03-30-2012, 02:27 PM
  5. Used Doughboy
    By Plumber199 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-23-2006, 11:08 AM
