Can't advise you on the pump and filter, but they do have problems recovering from water problems. My advice is to use bleach for your chlorine source, and run the filter whenever you aren't in the pool. The filter doesn't have great circulation, so you will have a hard time maintaining a chlorine level with tablets, and if you put any powdered shock etc. in you will have a hard time filtering out the cloudiness. Be very careful about adding anything to the pool because you don't have the luxury of a big filter to clean it up.Originally Posted by golfwig
