Results 1 to 8 of 8
Thread: Sand Filter & Pump Motor
    duraleigh Guest
    Default Re: Sand Filter & Pump Motor
    Jack,
    I just found a pump curve for a good, full-rated 2hp pump. Using a typical TDH of 50 for your pool (it could be more or less), you're pushing 130-140 gpm thru a filter only rated for 100gpm.
    OK great this is all great information for me to digest.
    Without changing the pump can't I put a 1.5 hp impeller on my StayRite pump. Maybe change the pump later. More torque but less water throughput and less money for now.
    My Chemical levels are ( from a 6 way strip)
    TH 400
    FC 2
    PH 7.5
    TA 80
    CYA 30-50
    Thia is a salt water pool with a Goldline Controls system.
    Thanks JK
    duraleigh Guest
    Jack,
    Changing the impeller is a good idea......I think.....I have no personal experience. I would get the tech support folks to walk me thru it. Sounds like plan to me, tho.
    I,m gonna' PM you about your water condition late this evening....I'm out of town right now and have to get off this computer.
    You could also buy a smaller pump and sell the 2hp pump on Ebay. I did that with mine and ended up spending a total of $15.00 dollars on my new pump.
