Results 1 to 3 of 3
Thread: test kits
    Default test kits
    Are there any test kits that will test for FC above 5ppm? Right now I am using a Taylor DPD kit.
    IL.
    Default Re: test kits
    Do a search for shot glass method
    waterbear's Avatar
    St. Augustine, Fl
    any FAS-DPD titration test such as Taylor K-2006 or Ben's ps234 will do it. If you are using a DPD colormetric test (match up the colors) you can dilute the sample and multiply the reading by the dilution factor.
  1. HTH Test Kits
    By Barry J in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2013, 02:06 PM
  2. Pool Test Kits
    By dar0rn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-08-2011, 08:17 PM
  3. re: Test Kits
    By Sumo1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 12-11-2006, 01:38 PM
  4. Ben's test kits
    By DONNIE in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2006, 04:21 PM
  5. Difference in Test Kits
    By jrv331 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2006, 02:40 AM
