CYA question
We have just purchased our first pool, just filled it, very new to all of this. It is a 24' AG. I just purchased a test kit (HTH 5 way). I have been reading this site non stop and have a question regarding CYA. Without this reading I cannot use the BleachCalc correctly......right? I did a quick test and the PH was good, Chlorine was very low. I could put in a 2ppm increase desired but if I understand what I am reading, I need the CYA level and Ben's chart before I can put in a correct figure? (ppm increase desired)
Also, I know reading so far I want my CYA levels around 30-40 ppm......once there it should never increase if I use ordinary bleach, correct?....and it will only decrease through water loss and adding new tap water?
Thanks........I feel like I am slowly learning......I hope!
Meade
- You may not post replies
- You may not edit your posts
Forum Rules
