Thanks,
I am going to commit to lowering the CYA as the whole point in converting to BBB is to lower chemical use and cost. Taking off work Thursday and Fridayto drain and refill then start lowering the TA. Tested the tap water and the TA is 200 so that will be an issue.
I will jsut keep working at it and posting numbers for guidance and reassurance as I learn.
