I picked up the filter at Lowes or Home Depot. I think it was about $35-50 dollars and has the replaceable 2 micron cartridges. They advise against using this type of cartridge on a well with high metal content in the water. However I wanted to remove as many contaminants as possible even if it meant I had to go thru several cartridges to complete the fill. I think I used 3-4 for a 26000 gallon pool. I also bought a flex line installation kit for installing the filter ahead of the softener.Originally Posted by crackerjack
I have a 2nd whole house filter that I use for the end of the fill hose. To make that work I had to buy some hose fittings for the filter. All can be purchased at Lowes or Home Depot.
