Results 1 to 10 of 16
Thread: Review of "Ultraguard"
Threaded View
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Default Review of "Ultraguard"
    I posted a couple of months back about my pool resurfacing project.
    http://www.poolforum.com/pf2/showthread.php?t=886
    I learned a lot from these forums.
    I decided to go with an epoxy solution after I chipped all the old failing plaster and patched the potholes with mortar mix.
    The product I used was Ultraguard 4500, their mid-grade Epoxy.
    http://www.poolrestoration.com/
    The key was surface prep....and had I to do it over again I might have smoothed out the plaster a little better. As it is the pool is textured and not smooth....but thats not all bad.
    As for Ultraguard it looks to be a nice surface!
    There is a bond coat and a finish coat.
    The Bond coat is thin but created a really nice hard shell over the plaster and fiberglass walls. The stuff looks indistructable.
    The Finish Coat is a lot thicker and I had to race to get it on the pool before it hardened. The End result is a squeeky smooth clean finish. Hardened out of the bucket it feels like a plastic, on the pool it feels almost like glass.
    I cant see it ever popping off by itself...it will certainly never come off of the paint equipment I used Time will tell if it stands up over the years and I'll be sure to report with pictures.
