Thread: Pump timer question
    Rehoboth, MA
    Default Re: Pump timer question
    The "ideal" timer settings probably depend on your individual circumstances - when do you add chomicals to the pool? you probably want the pump running for at least an hour after you do that - when is it likely that the pool will be used the most? how much sun do you get? are you using a solar heater? does the water get too warm? - The answers to these questions should help you decide when to run your pump. I don't think there is any "wrong way" to do it. I run mine from about 9am to 1pm then 5 to 9:30PM. Based on my pool volume and pump I need to run my pump for 8 hours to get 2x the volume pumped through it.
    Peter
    Central Texas
    I can't find the link, but it said run the pump for one hour per 10 degrees F of temperature. Not sure if that was air or water, but I'm in central Texas so I'm running it 9 hours a day, from 11AM to 8PM. That schedule gives me some time in the evening after the sun is off the pool to add bleach and acid.
    I run the Polaris 180 booster pump for only a couple of hours near the front end of the main pump time. We swim mostly in the afternoon, so this schedule makes the pool nicest for that.
