Thread: 45000 gallon pool third week using bbb
    Default Re: 45000 gallon pool third week using bbb
    I remember reading on the old forum that each pool's ph tends to be different. Some tend to drift up and others down. Why? One thing is the type of chlorine you use.
    Bleach tends to cause the PH to run up. Some pools faster than others. Keep up with the Muratic Acid. I don't understand the dynamics of PH and scaling on plaster, but you may need to lower your PH down to 7.2 and let it drift up to 7.6 and then add more acid to prevent the scaling since you are getting that at 7.8
    Good Luck!
    mbar's Avatar
    Ashland, PA
    Your plaster is still curing.
    Northeast PA
    Sanford, FL
    plaster curing causes increases in PH - having to reduce it is normal
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
