I did an owner built pool so I learned as I went along. My pool is finished with a Diamond Brite type finish called Millenium. When the plaster finished and the pool was filled (I had a tanker fill pool in less than an hour), the plasterer guy added about 8 gallons of muratic acid. He told me to brush plaster two or three times a day and add 2 more gallons of acid on day 2 (to keep PH around 6.8). After the third or fourth day of brushing, the amount of plaster dust brushed up with each sweep started to diminish. By day 5 the water was looking pretty clear. The pump was running 24hrs a day during all this. On day 6 I added the stabilizer (CYA) and bleach. The PH was steadily climbing and was around 7.6 by then. I was swimming on day 7. I also added a litttle more acid to keep PH down to 7.4 - 7.6.Originally Posted by bradjo
P.S. It is important that you put the DE powder in soon after running the pump. My DE filter instruction say that over 15 minutes of running without DE can damage filter. If you run without it you may tear the membrane. As you brush and filter the water the filter pressure will rise with the build up of plaster dust. Be prepared to backflush (or disassemble and clean) at least once before the week is out.
Good luck
