Thread: "ph minus" into skimmer
    WI
    Default "ph minus" into skimmer
    I understand 99% of you guys do not use a chemical called PH minus, but instead use acid, but like a idiot I dumped about half a quart of mix with water PH minus into my skimmer, before realizing that I need to just dump it into my return water area. It is about a half a hour later, and the pump seems ok, etc., but what do I need to look for/could happen? I really dont think it hurt anything, but if someting does happen I need to be able to come up with a story to my wife...someting along the lines that the dog did it. (we don't have a dog)...
    Cheesehead newbie idiot
    I forgot to mention, 18ft ag with Hayward pump/sand filter. And I hate pool stores too!
    Default Re: "ph minus" into skimmer
    You should be ok if you only did it one time. If you had a cartridge filter there is a greater risk of damage to the filter element but sand filters are fine.
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  3. how should I "cut in" skimmer and return holes in the liner?
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 07-06-2007, 12:53 AM
  4. Skimmer replacement "circular weir" questions.
    By Socal_biker in forum In-Ground Pool Construction and Repair
    Last Post: 10-10-2006, 04:55 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
