Results 1 to 10 of 10
Thread: For those who have/have had trouble with GFCI breakers......
    Connecticut.
    Default For those who have/have had trouble with GFCI breakers......
    Today I came home to find out that my GFCI breaker tripped sometime between last night and this morning. We had a rain storm, but nothing near like we've already had, so my thought is its not moisture.
    Anytime I plug my pump into the GFCI circuit, the breaker instantly trips. If I leave a receptacle on the circuit, even without anything plugged into it, the breaker *eventually* trips (minutes, hours later, etc.) Currently have bare wires (covered of course) outside with the breaker on waiting to see if the breaker trips all by itself.
    Any ideas? I know a couple people recently had issues liek this, would be interested to see what fixed it....and also anyone that may have had something liek this happen (this actually happened to me 2 seasons ago, I thought it was fixed because it worked fine all last year and so far 2 months this year).
    Thanks in advance.
    -Chris
    Indiana.
    Default Re: For those who have/have had trouble with GFCI breakers......
    GFCI Breakers can and do go bad, but more than half the time it is moisture somewhere. It doesn't take more than a heavy fog to cause problems.
    Oxford, MS
    We had this problem with a GFI in the house. Changed out the switch and it continued. For weeks we searched for the problem. Drove me crazy. It was a new home and I was ready to call the builder. Finally I discovered the motorhome plugged into an extension cord which had fallen from it's hook and sunk into a puddle of water. Lucky my mom taught me to stay clear of mud puddles! Good luck.
    AG, vinyl, 30' round,
    24,000 gal, Sand filter
    The message is, at the moment, NOT that the GFCI is bad, but rather that it's doing it's job and there is a "leak" somewhere of electricity, which is VERY dangerous. Unless you can PROVE the GFCI is bad, assume it's good and finding a problem.
    Connecticut.
    The GFCI *breaker* (not an outlet) only goes to the pool (about 100' directly from panel to equipment pad). Whats odd is that I havent dug, drilled, etc. anywhere near it. I agree that its probably a leak somewhere, but the 2 ends of the wire that I can see are fine (circuit panel end and equipment pad end).
    To throw another wrench into the works, I re-installed the receptacle (the same one that tripped the breaker last night) and now not only does it not trip the breaker, I was able to plug the pump into it and the pump is running fine off the outlet.
    Unfortunately Im not 100% sure this cures anything. Considering I thought this issue was fixed last year, short of re-running the whole circuit, how is there any way to be sure? Im hoping I just need to replace/re-wire an outlet every year or two, but that doesnt make sense (why didnt the pump run when connected directly to the wires feeding the outlet that now mysteriously works?)
    -Chris
    I also had a GFCI go bad after about a year of use, replaced it with a more expensive model, 2 years later, still going strong.
    adl6009 Guest
    I had a gfi socket do that to me. I had my low volt landscape lights plugged into it and every couple of nights, sometimes 2 weeks would go by, and the gfi would be tripped. I could never identify a cause. So I changed out the gfi socket and it hasn't happened since. (About a year now) They do go bad, I guess mine was tripping for no good reason.
