Thread: Testing cya level - HTH kit
    NJ
    Default Testing cya level - HTH kit
    I bought a HTH 5 way test kit to test for cya level. My problem is the test tube doesn't test below 30ppm. Is there any way I can test for a lower amount so i'll know how much to add?
    Default Re: Testing cya level - HTH kit
    add enough to raise your CYA 20 ppm. this way you will either be below 30 ppm or no higher than 50 ppm (range to shoot for is 30-50 ppm). If you test within range at the next test you are fine. If you are testing low then you should have enough to register on the test to get an idea of how much more to add. If the test still doesn't register then you had no cya and you should now have 20 ppm so add enough to raise it another 20 ppm and retest. You should then be around 40 ppm but should be no higher than 50 ppm.
  1. Intex Ultraframe 12x24 How Level is Level?
    By DMDPT in forum Intex-type Pool Setup & Operations
    Last Post: 07-29-2012, 03:20 AM
  2. Replies: 5
    Last Post: 06-05-2012, 09:22 AM
  3. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  4. Salt water level testing
    By doriec in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2007, 09:51 PM
