Quote Originally Posted by Rangeball
FC can never be higher than TC, as TC= FC plus CC. What testing method gave you these results? Did you do it yourself or where they from a pool store?
Your CYA is at the uppermost recommended range. Your PH is at the lowest end of the recommended range. Chances are good you are head towards the problems I posted above.
If it were me, I would stop using the pucks right now. I would verify my chlorine readings as something is wrong there. I would consult the "Best Guess" CYA chart (it's a sticky at the top of the chlorine forum), download Michael Smith's excellent "bleach calc" program (it's in his sig line when he posts), figure out how much bleach I need to add to get my FC to the upper end recommended in the best guess chart and keep it there by adding the required amount of bleach every night after dark.
This year I opened my pool, shocked it, then I've added .75 gallons of 6% bleach every night (adds 2.1 ppm to my pool). Water has been crystal clear, haven't had to shock again.
Last night I tested wiht the Taylor KIt and as follows:
FC3
TC3
CYA 40
PH 7.5 Had drifted down and two ights ago i added PH increase to move it up from 7.2
Alk 100
Please clarify? You use bleach every night but do you use the same kind of bleach to shock? I guess my question is, is ther a diffence between dailyl bleach use and shock bleach?
Thanx everyone. This site is fantastic.
