Re: Stains and test results..........
Welcome to the forum, I will try to help all I can.
First your chlorine level is not high enough for your cya. You should have a minimum of 8, and run it somewhere between 8 and 15. You will need to get to 25 to shock. Here is the "Best guess chart"
Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
=> 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
=> 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
=> 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
=> 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
=> 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
Second your calcium is not high enough for a gunite pool. It should be between 200 - 400. You will have to add some calcium, but don't add what it says on the container. Add less, and check the next day - the only way to get rid of too much calcium is to drain and refill, just like cya.
You can do a partial drain and refill to lower your cya, but you can also run your pool with a high cya as long as you keep your chlorine levels in the right place. It may be easier for you to keep higher cya since you are away alot.
Your alkalinity is good.
You have no cc, but sometimes you can be starting on algae without it showing up, so it wouldn't hurt to take your chlorine up to shock levels and leave it there for a while, it will help to get rid of the stains. A chlorine of 7 in a pool with cya of 100 will not lift the stains - it will barely keep algae at bay. You can try to crush up some chlorine tabs, or just rub them on the stains and see if they go away. If they do, then they are organic stains and will go away with bleach. If they don't rub off with chlorine, then you can try crushing up some vitamin C tablet (ascorbic acid) and put them in a sock and rub them on the stains. If the stains lighten up with the vitamin C, then the stains are from metals.
Hope this helps, let me know if you have any more questions.
Northeast PA
