Results 1 to 10 of 14
Thread: Help chemical balance whacked
    Default Re: Help chemical balance whacked
    Quote Originally Posted by katw78
    It definitely does sound like an algea problem. This will drastically raise your PH. You have to bring your PH down or the algea will continue to thrive. This will also help make your chlorine/sanitizer more effective. There is also a really great algecide that you can get for about $25 at walmart that takes care of almost every type of algae imaginable (including mustard). It is called "algae free". I would dose heavily with that and try to brush the walls and steps/ladder down as much as possible and the vaccum well. (We even took our steps out and bleached them and the sandbags that go inside to hold them down.) If you don't get the algae under control, you'll never be able to get the PH under control, and that will make it harder to level out your chlorine levels.
    You also need to bump up your stablilizer, but be careful not to over stablize because this could cause more algae problems. I would up it by what the bottle says, but then be sure to test it reguarly (morning noon and night) to make sure that the levels are in range and not too high. Good luck!
    I would suggest you read through the forum and then go to www.poolsolutions.com and read everything you can on there to see how this forum recommends dealing with problems like algae. You recommened an algeacide and I am wondering what is the active ingredient in it. If it is copper it is DEFINITYLY not a recommended product. If it is sodium bromide or inorganic ammonia compounds then it can create a whole new set of problems. If it is a linear quat it is also not a recommended product. If it is polyquat it is fine to use but only after chlorine itiself has not proved effective.
    Also please explain to me how an algae bloom will raise pH?
    I agree with waterbear...katw78, please take some time and read around the forum before you start posting advice. We have some tried and true methods for clearing up water problems that don't involve dumping other stuff in the water that may cause other problems later.
    Also, I'm curious about your reasoning behind the relationship between algae, pH, and chlorine levels--while lower pH may or may not help your chlorine be more effective, I have absolutely NO knowledge of algae blooms creating pH problems.
  1. Is chemical balance importance in winter or off-season?
    By CandyMoss in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 11-24-2013, 01:42 AM
  2. ph and alk balance
    By paigemetoo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-18-2013, 03:39 PM
  3. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  4. Chemical Balance questions
    By Azsnook in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-17-2012, 05:45 PM
  5. Re: Help chemical balance whacked
    By katw78 in forum The China Shop
    Last Post: 06-26-2006, 09:48 AM
