Re: Help, Pool looks like lime koolaid
Fisrt thing to do is to stop using test strips to try and adjust your pool chemisty by. While test strips are accurate they are not precise (a difficult concept to explain but look at your pH reading...between 7.2 and 7.8! that is a wide varience! There is a BIG difference in the activity of your chlorine at 7.2 and 7.8!)
Look for the HTH 5 way or Aquachem 6 way test kit that uses reagents at your local Walmart or Kmart. Best value in a test kit under $20. Or go to a pool store that uses either Taylor or LaMotte testing with reagents and post a full set of numbers and we can give you much better help!
Am not familiar with the Algecide you used but it might be ployquat 60 which is the only type that you should use. If the ingredients list poly (long chemical name) at a concentration fo 60% then you have the good stuff!
Also disreguard the bromine reading on your test strips...You have a chlorine pool. The same test is used for both chlorine and bromine but bromine will test twice as high (and needs to be run at higher levels also).
