Results 1 to 10 of 15
Thread: working a DE filter
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    Default
    Quote Originally Posted by blk133
    Could be this one, there are Hayward EC 50, 65 75 I think.
    Here is the attachment
    actually mine looks older than that. Mine doesnt have any black on it at all. It is all beige with a bunch of little bolts that hold the top cover on.
    and when I say high, the psi was somewhere around 30 and I remember the previous owner saying that it should be somewhere around 15-20 i believe.
    if it stays pretty warm today I will open up the filter, hose off the inside and put some more DE in it and run it.
    one more question, how do i determine how much de I need?
    kaybinster Guest
    Default
    As long as you have good water flow pressure really does not matter, what you want to look at is increase in pressure over time. You should record the pressure when you first coat the filter and then backwash it when the pressure has increased by about 5 psi.
    Dec 2005
    Athens, Georgia, US.
    Default
    re: how much de I need?
    I was told that my 25000 gal pool needs 7 one pound coffee cans of DE each time I clean it. This is also supported by the chart on the DE bag. I was also told to add it slowly thru the skimmer without mixing it with water first. This forum seems to advise premixing it. I would appreciate any advice on this - should I premix or add directly to the skimmer?
    Bill Marshall
    kaybinster Guest
    Default
    Always premix it with water to get a nice slurry otherwise it will clump up in the filter rather than properly precoat the filter.
    Default
    Quote Originally Posted by fog80
    Yours then is Hayward EC 65 or EC 75. Do a search in google for Hayward EC 65 and look at the picture.
    I have EC65 (beige), they used to be beige, now they make them in gray color
    My pressure is between 18-20 with 1 1/2 inches piping
    Some info I found on backwashing:
    Turn pump off.
    Open backwash valve.
    Bump handle slowly 15 times.
    Turn pump on and run it for 2 minutes.
    Turn pump off.
    Turn pump on for 1 minute.
    Turn pump off.
    Close backwash valve tightly.
    Turn pump on.
    Add D.E. to the skimmer located closest to pump.
    For Hayward EC-40 / EC-50 Filters use (3) 1 LB coffee cans of DE
    For Hayward EC-65 / EC-75 Filters use (5) 1 LB coffee cans of DE (some websites say for EC-65 it's 6 lbs and for EC-75 it's 7 lbs)
    I don't think it will hurt to put 6 lbs even if it's 5 that it needs.
    Add D.E. to skimmers SLOWLY. Don't CLOG them !
    Check pool water level after backwashing - add more water if necessary !
    Hope this helps.
    B.
    Default
    Turn pump off.
    Turn pump off.
    Turn pump off.
    Turn pump on.
    Hope this helps.
    B.
    thanks I think your right.
    I just found some paperwork the previous owner had left and he said to add 6 lbs of DE after backwashing.
    Default not a 'dis' but the info's no go
    Turn pump off.
    Turn pump off.
    Turn pump off.
    Turn pump on.
    Hope this helps.
    B.
    Sorry, but 'bumping' again after the water is out of the filter won't do anything. The way I've always done an EC-(whatever) is to;
    1. Turn the pump off.
    2. Open the air relief valve for 5 sec. - to relieve the pressure.
    3. Push the handle down SLOWLY and raise it up Quickly. Repeat 4 - 6 times.
    4. Open the bottom plug on the filter( some smart installers put in a valve).
    5. turn on the pump for a minute (+/-) till the water runs ~clear.
    Hooray! You just got a bunch of your DE out. If you have water in the pool to spare, replug the bottom drain, run the pump for a couple of minutes and do it all over again (steps 1 - 5). You will see more 'stuff' comming out of the a** end of the filter.
    The big piont is that you won't get more than 80% of the stuff out, so only add ~ 5 lbs back into the filter when you put the DE into the skimmer - 'more is better' is a typical American ideology' - and it's usually wrong.
    Sorry to contradict the previos poster, but you came here for good info and his is just a little off.
    Default
    thanks a lot.
