Thread: Question About Chlorine Safety
    Red face Question About Chlorine Safety
    Hi, I have a 15' round AG 5,000 gal. I inherited it with the house I'm renting, 2nd year. Last year no problems, this year had an early green algae bloom, which I took care of, but now have been battling cloudy water 3 weeks. I discovered this forum this past week and after doing some things suggested here my pool looks better than it did all month. I can finally see the bottom but its still cloudy. I added some De to my sand filter, and bleach to the pool. I got the FC and TC to 10 ppm. I'm also using trichlor pucks, two in feeder. My CYA was at 0. I decided to go to the pool store yesterday to test the water. I'm using Aquacheck select test strips. They were pretty accurate with most of the pool store results.
    Pool Store, My results:
    CYA O, O
    TC 10, 10
    FC 10, 10
    PH 7.8, 7,7
    TA 145, 180
    TH 203, 250
    The pool store sold me CYA which I added, but they also told me my sanitizer is low. Isn't 10 shock level with no stabilizer? Also if I bring the FC up to 15 ppm to finally clear the cloudy water is that safe for my children (ages 12 and 9) to swim in, or should I wait for it to come back down. They are giing crazy waiting for pool to clear. Thank you for this forum, you helped me so much but I still have a long way to go. Am going to go the BBB route!!!! Carolyn
    Sanford, FL
    Default Re: Question About Chlorine Safety
    Don't listen to the pool store person - your chlorine levels look good. I wouldn't let the kids jump in until the chlorine is below 10ppm.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Thanks for responding
    With a CYA of 0, the Cl needs to be below 5 or so before you no longer risk fading bathing suits, but the good news is that on a sunny day it won't take long at all for your Cl to come down! Also, make sure that your pump is running 24/7 while you're clearing up the dead algae..the chlorine kills it, but the filter is what removes it from your water.
