Results 1 to 10 of 12
Thread: Replace Jandy Ray-Vac?
    Default Replace Jandy Ray-Vac?
    My Jandy Ray-vac has serviced my pool pretty well. It began to fall apart (my chems off balance?) bit by bit last season, and now it isn't that effective in making turns, or sucking for that matter. I'd like to replace it, but want to know what the easiest way is. I'm confused with reading some of the recommendations, because they never mention how the equipment gets attached: extra pump vs. no pump needed. I'm guessing my Jandy has no extra pump. It gets a feed from the filter, and the water propels it and causes a suction?
    What product can I buy, and just unhook the Jandy, and hook in the new product? How do I classify this type of cleaner?
    Thanks for any help.
    Chi
    Elias is offline ** No working email address ** Elias 0
    Default Re: Replace Jandy Ray-Vac?
    I am in the same boat your are. I would appreciate any input anyone has to offer. I am tired to replacing parts in the Rayvac after a couple of years and it is never quite right for whatever reason.
    I am considering the MARS HP™ from Zodiac. Does anyone have any info on this unit? It is also pressure side, but I am not sure if it requires a booster.
    Eli
    BTW, I am on my second Rayvac. Nice unit when it works, it just seems to wear quickly.
    Downingtown, PA
    Any pressure side, non-booster pump cleaner should be a fit for Ray-Vac.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    48 Sq Ft Hayward D.E. Filter (2003)
    1.5 hp Hayward Super Pump (2006)
    Westminster, MD.
    I just replaced my RayVac with a Polaris 360. Just had to replace the hose fitting in the return. I got my Polaris on eBay for a great price.
    I tried the Polaris and I liked the RayVac better. Maybe I didn't have the 360 though? I don't remember which model I had.
