Thread: Acid startup 3M Colorquartz *NEWBIE HELP!!*
    Default Acid startup 3M Colorquartz *NEWBIE HELP!!*
    Hi;
    We are owner builders and the pool is now plastered. The plasterer's couldn't give much specific information and 3M refused. I found some powerpoint slides online talking about Exposed Aggregate Water balance:
    Week #1
    pH 6.0 - 6.5
    Alk 60 - 70 <- confusing I thought should be 0?
    Ca 190 - 200
    Sequestering 15 - 20
    We are to brush 2 times a day minimum. My question is do we run the pump/D.E. filter during this week? I'd be worried the pH would ruin the equipment especially the heater? How about the Metal SAM/SAL light rings won't this ruin the metal? Should we add a anti-stain agent? If so which one? Would tomorrow night be to late? (hate to ask hubby to take another day off & I can't drive).
    Week #2
    pH 7.0 - 7.6
    Alk 60 - 70
    Ca 190 - 200
    Brushing once or twice a day until we get aggregate appearance, get rid of any white streaking, smooth out plaster. Once the pH goes above 7 start the pumps and filter?
    Anyway with the pool filling as we speak (It's almost filled and I'm staying up to do the first water test) I'm terrified to dump in Muriatic acid with those metal light rings!
    Help!!!!!!!
    Jo
    Default Re: Acid startup 3M Colorquartz *NEWBIE HELP!!*
    Quote Originally Posted by bradjo
    Week #2
    pH 7.0 - 7.6
    Alk 60 - 70
    Ca 190 - 200
    Help!!!!!!!
    Jo
    I cannot help you on SOME issues but on others I can.
    Alk or Total Alkalinity (TA). This only OK where it is, but it's not too high, it's TOO LOW! Yup, it's a buffer that keeps pH from bouncing around, and should be in the 80-125 range for your pool.
    Calcium should be in the 200-400ppm range to keep it from dissolving the calcium out of your new plaster walls. You can add calcium for that.
    As new plaster pools cure they push pH 'way up...so expect that.
    As for the acid treatment and brushing of the new pool, I'm not grounded enough in that to help at all.
