Thread: More 234 results
    Default Re: More 234 results
    Most people run their pumps 4 to 5 hours, twice a day.
    I don't know how to figure that out, but for someone to help they will need to know the type of filter and it GPM rating.
    duraleigh Guest
    How do I figure how many GPM I'm pumping???
    Look in your pump documentation or go Hayward's site and find the pump curve for your particular model. It will give you gpm vs. tdh(head). If you don't know the tdh of your pool (not many of us do) mas985 has indicated that 50 is good number for most pools.
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    Thanks! That should do it. I appreciate your help.
    Rehoboth, MA
    Here's some info from one of the posts in the pool equipment section:
    Most pools require 1 to 2 turnovers per day. What is turnover?
    Turnover is the time it takes for the volume of the pool to run through the pump once. However, this does not mean that all of the water has gone through the pump. Some water goes through once, some twice and some not at all. To determine turnover rate:
    First, determine the head loss for your plumbing. It is usually between 45-65 feet of head. If you want a better estimate, take your filter PSI and multiply this by 2.31. If you do not have a vacuum gauge, add about 10' of head for suction head. Otherwise, multiple the vacuum (in. mg.) by 1.13 to get suction head. Add return head and suction head to get total head.
    Second, look up the the flow rate from the pump head curve that is usually in the manual. The vertical axis is head loss and the horizontal axis is GPM.
    Third, use the formula turnover (hrs) = Pool Volume (gallons) / (gpm * 60)
    Yes, it is usually a good idea to split the filtering time into two parts evenly distributed within a 24 hr period.
  1. first results, please help
    By vinouspleasure in forum DPD-FAS based testing
    Last Post: 06-13-2010, 02:42 PM
  2. Pool store results vs my ps223 results!
    By scarywoody in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2006, 06:47 PM
  3. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  4. My Results...Do I need to do anything?
    By albertgarrido in forum DPD-FAS based testing
    Last Post: 05-27-2006, 08:28 AM
  5. First set of results
    By maker in forum DPD-FAS based testing
    Last Post: 05-25-2006, 09:48 PM
