Re: On-line testing instructions?
I have the HTH 5 way Test Kit.
Most I remember or are easy to figure out but te CA test is muddled. I can't read the fill mark for the larger tube and if you are to add the drops up to the 14 ml mark?
I do remember it took a lot of drops.... thanks for any help. I SHOULD have waterproofed mine!!
Been searching the net, but so far not much luck.
