Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
how to lower if I need to? alkalinity of 170
FAQ
register
Results 1 to 10 of 13
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
06-22-2006
06:06 PM
#3
timmie
View Profile
View Forum Posts
Registered+
Thread Analyst
manitoba, canada
Re: how to lower if I need to? alkalinity of 170
I thought once it reaches a certain level that you cant swim ( alkaline)
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Fine Tuning Testing Precedure w/ Taylor 2006
Green (algae ?) water-test results karenkr
Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
By heyaim in forum Dealing with Alkalinity and Calcium
3
Last Post:
07-22-2012,
07:51 PM
Help with trying to understand how to get Alkalinity lower
By Rosie700 in forum Salt Generators (SWCG) & other Chlorine Feeders
4
Last Post:
06-24-2012,
11:48 PM
Pool store advice to lower alkalinity - three day muriatic acid dose method
By aquarium in forum Dealing with Alkalinity and Calcium
14
Last Post:
07-03-2006,
11:04 PM
How Do You Lower CYA?
By cheshamjim in forum Testing and Adjusting Pool Water Chemistry
19
Last Post:
06-17-2006,
01:53 PM
Should I lower my alkalinity?
By dhale63 in forum Dealing with Alkalinity and Calcium
4
Last Post:
05-16-2006,
11:21 AM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
