If Ben does not start offering a salt test kit separately you can get one from Taylor. They have 2 different chloride test kits in the pool and spa section. the one with the 2 oz bottles of reagents uses the same reagents as Ben's kit. It's a bit pricy. You can upgrade to the PS234S and use your reagents from the 233 with it also and the upgrade is only about $20 more than the chloride test kit from Taylor (if I remember the prices correctly, might be wrong but I am not off by that much).
At least, that is the route I would take--ordering the ps234s and using the 233 reagents with it. they are all compatible if I am not mistaken.
