Thread: Pool Shock at Wal-Mart
    Texas
    Default Pool Shock at Wal-Mart
    I saw some shock at Wal-Mart that said it did not have have stabilizer in it. Is this something new or has it been around a while?
    The number of people staring at you is directly proportional to the stupidity of your actions.
    Default Re: Pool Shock at Wal-Mart
    It's probably cal-hypo, which is the main ingredient in many prepackaged shocks, and is not stabilized. It's been around a long time..
    Be aware that the cal hyop shock at walmart is NOT full strength. It is 45-48%. Normal strength is 68%. You will have to add more of it to reach the same ppm of chlorine in your pool! I believe 1 lb will raise 8000 gal to 10 ppm chlorine while full strength cal hypp will raise 10000 gal the same amount.
  1. Wal-mart bleach $ increase
    By oldkingcole in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-27-2011, 02:20 PM
  2. Newbie: To shock or not to shock... That is the question
    By KaseyNewman in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2011, 04:50 PM
  3. Detection limit for Wal-Mart kit CH test??
    By Henrys514 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-14-2006, 09:56 AM
  4. Wal-Mart shock
    By RknRusty in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-18-2006, 10:15 PM
  5. Wal-Mart bleach...what %
    By JMCFAN in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-09-2006, 09:25 PM
